Kaldskryke
- Aug 1, 2004
So this was my first time watercooling. I've stuffed a dual-rad loop into an A05. There's a 120x240 rad up top and a 120x120 rad on the rear intake. I've put the reservoir in the niche behind the hard drives and left the pump on the case floor on some soft cloth (to damp vibes). I hadn't really expected how difficult it would be to connect everything up without kinks and whatnot. I also was short a couple 3/8" barbs so I had one small section of 1/2" (I could find tubing locally, but not barbs). In the end it was kind of a mess but I lived with it.
Recently, the tubing has begun to relax a bit, some of the bends are getting sharper and kinking. Plus one section of tubing now rests against my sidepanel, making it rattle and buzz. It's driving me nuts so I want to rearrange or fix my loop to hopefully A) get rid of kinks, B) stop that buzzing!
Here's the front currently. Note the tube towards the bottom of the image and how it sticks up against where the side panel goes. The tube on the far left is the 1/2" one, and it's gotten kind of wrinkled somehow.
Here's the back
So the flow is as follows: from reservoir (behind hard drives) -> pump on case floor -> single rad on back -> cpu block -> double rad on top -> back to res.
There's not much watercooling equipment selection in Calgary, so I want to check here before I try buying things like "smartcoils" and 90° barbs from NCIX. I'm also terrible with cable management so any pointers there would be welcome too.
Here's the back
