Help Me Quickly
Pegesus
I am trying to connect my case fans and my psu fan where do i connect them to the motherboard.
I connect my cpu fan to the cpu fan adapter
I connect 1 of my case fans to sys fan adapter
i connect 1 of my case fans to my power fan adapter
all i have left is the psu fan/moinitor adapter and the only other fan adapter on my board is an NB adapter will it work there or did i do something wrong?
you mean i cannot connect all of the them atm or what can the computer run without overheating i need more info please
i think he's just confirming that he has it right.
you connect the CPU fan to the 3 pin socket on the mobo right next to the CPU.
you connect the other fans to the other 3 pin sockets on the mobo that are anywhere else but the CPU. if there's only 1, plug the exhaust fan into that one, and plug the intake fans into the molex adapters you got with the fans, and plug those into the power supply molex plugs.
