I'd be grateful for help with a new system build.
Background: I have a system that is about 2.5 years old that I built with help from people here. I'm seeing frequent (a few times a week) crashing (memory errors or similar) and then also times when upon startup I get video errors. I plan to take this system apart and use it for a backup, but I'd like to put together a new primary system. I'd really appreciate everyone's help with this. I'm a computing professional, but not really a hardware guy. Whenever it comes time to build a new system I immerse myself on things here at this site to try to figure out the best components.
My primary use is running business software, although I will also use it for some gaming. (Gaming expectations are not high performance. Civilization V is my favorite game.) Being able to run widescreen dual monitors is a key concern.
A target is $3,000, but that is flexible. I usually put together a new system every 2-3 years and try to use the best equipment available at that time to get a system with good longevity. I can spend more if it is worth it.
U.S. I live in eastern TN. Johnson City.
I have a set of parts I'll be reusing (see next question). Other than that I need everything. I think that would mean (1) case, (2) motherboard, (3) processor, (4) memory, (5) power supply, (6) video card(s). My biggest concern is figuring out the best option for (2) and (6). I also will need some desktop speakers. Right now I'm doing HDMI audio from one of my monitors, and it stinks. I'd like my budget to cover (1)-(6).
I have two Dell UltraSharp U3415W 34-inch Curved LED monitors that I'll be re-using. I also have a couple of SSDs I will probably use as 2nd or 3rd drives. Although I don't have it yet, I plan to purchase a Samsung 850 Pro SSD drive as the primary system drive. (Unless someone talks me out of this.) I have a blu-ray writer I'll put in as an optical drive (although I rarely need it).
6) Will you be overclocking?
No. At least that's not what I have planned
3440 x 1440 times 2 monitors. Each monitor is 34 inches.
I'm ready to start ordering components now, but I'm assuming it will take a few days for some replies here and for me to do my own research. I'd hope to have this built before Christmas.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0 definitely. Don't think I'll do RAID. As far as Crossfire or SLI, I need advice. Right now I'm running a single GeForce GTX 660 video card to drive both monitors. It doesn't seem up to the task. Probably SATA 6Gbps to get the most out of the SSD. I don't currently own anything that would require eSATA. Onboard video--not important. UEFI sounds good.
I plan to install a properly licensed Windows 10 64 bit.
I feel like the component that is the biggest mystery to me is video cards. I don't need anything for high-end gaming, but I need something that will drive these two beasts of a monitor well in an environment where I do serious multitasking.
