Help Me Please!!!
Instakilla
Ok so i just got everything for my new computer today and assemled it all and am now trying to get the stupid thing to load a windows xp cd to reformat and reinstall. i have tried 2 diff windows CDs and neither loads and on top of that 1/2 the time i restart my system it doesn't regonize the monitor and i have to restart again. any ideas? cause i am getting rather annoyed.
So sometimes the CD is loaded and gets half way preparing for setup and then the system restarts!
please help me guys
please help me guys
What's the psu you are using and is it 24 pin?
yah in my sig and the psu is 24 pin
its getting to the point where i can get windows into setup mode but stops in the middle of the setup. doesn't shut down or anything just stops
1. Speak English
2. Type as though you are literate, with punctuation and upper and lower case
3. Submit your system compoents (in your signature would be ideal)
4. Raise your DDR voltage to 2.75
**DFI LANPARTY UT NF4 ULTRA-D**
*AMD ATHLON 64 3200+ PROCESSOR S939*
** OCZ DUAL CHANNEL OPTIMIZED 2X512MB DDR PC3200**
*SHAPPIRE X800XL PCIe 256MB*
**ZALMAN CNPS7000B-ALCU**
*80G and 120G Seagate HD*
that is my rig
here is my problem. whenever i try and setup windows for reinstall, it will make it as far as detecting the drivers and then just lock up on my, doesn't shut down by itself or restart. Just freezes up. i have tried upluging everyhing but the bare min. (videocard, keyboard and CD drive) but it just continues to lock up at the same screen. but never on the same driver.
THis seems to happen for some ppl. What BIOS version do U have?
I would go here and get some help. Be sure to read the stickies.
And then in one of the stickies RG (DFI employee) asks for ppl like U to help him with info.
Its this thread
Now if you cant get it up and running with the help of those guys its RMA tmie :)
