help me please
is there any way to update a bios through another pc...usb to usb or flash drive? My new maximus formula will not post past TESTCMOS on the little lcd poster...looks like im gonna have to buy a chealp LGA775 cpu to update to newer bios because my e8500 wolfdale is not supported as i have the first gen maximus formula...any suggestions on a cheap 775 cpu? I hope some one can point me in the right direction and it would be so greatly appreciated.
Thank you for your time:(
Did you buy the MB not knowing the 8500 wasn't supported????
Or were you hoping that the BIOS that was shipped would be new enough???
You are going to need to get a S775 CPU that is supported by your current BIOS, install it,then update the BIOS.
ASUS EZ Flash2 is the best way.
Download the new BIOS, put it on a flashdrive,enter the BIOS,go to tools,go to EZ Flash, put the drive into your USB slot, the EZ will find the new BIOS, follow the instructions, install the new CPU.
I had to do this before. I bought a cheap P4 that would work and went from there.
Yes that's what it looks like im going to have to do..thank you so much for the reply..have a nice day.
