Help me please :)
cuse
Hi all,
I am not sure if I am posting this in the right place... but I have a problem with my new PC and I'm trying to figure out if it is the video card or the monitor or maybe neither that are causing the problem (so I am going to post this in both the video card and display forum).
I just built a new PC for the first time - AMD X2 4800+, 2GB RAM, 2x 160GB SATA Seagate HDs, X-Fi sound card, liteon optical drive, MSI K8N Diamond Plus motherboard, and evga 7900GTX 512MB RAM video card. I also got a ViewSonic VX2025wm monitor for it.
So I think everything is setup correctly, and I boot the computer for the first time. Everything is great, the lights go on, the fans are spinning (all of them), etc. But the monitor just says "no signal" and then goes black.
I try connecting it with DVI, D-SUB, both, everything. Not working. I call viewsonic support and they tell me that the monitor says no signal because no OS is isntalled and that I need to install the OS before I can use the monitor. So my question is... HOW can I do that? (I am on a laptop right now and don't happen to have an extra monitor laying around - like a CTR - to isntall the OS).
Could this maybe be a problem with my video card not working properly and not sending the signal? Or do you think it is more likely the monitor? And either way... what do you think I should do to try and solve this annoying/nasty problem.
Any help/advice is MUCH appreciated! Thank you. :)
This happened to me once. The problem was that I didn't have the video card seated properly. Soon as I pushed it down and heard an audible click, I had video.
To test your new monitor, plug it into the laptop you are on right now.
Good luck
P.S. Another thing to try.... Put in only one stick of ram, if it still doesnt work, try the other stick. Bad ram will cause the kind of symptoms that you are describing.
BTW that is some nice hardware.
This is the biggest BS i've heard in a while. If that is any indication of the knowledge of Viewsonics TechSupport, then i will stay far far away from their products. You should see a so called "post" picture. The post picture is the display of basic information about your computer (called "Bios"). Every computer in the world has a Bios and the bios pages can be seen without any operating system installed on it. You are completely right with your assumption that you can't install the OS without this. I wonder what the Viewsonic rep was thinking?!
Anyways, reseating the video card sounds like a good start. Also, do you get any beep codes from your computer?
