Sep 10, 2008 #1 D da233 Limp Gawd Joined May 3, 2007 Messages 303 http://www.newegg.com/Product/Product.aspx?Item=N82E16820171362 vs. http://www.newegg.com/Product/Product.aspx?Item=N82E16820220263 vs. http://www.newegg.com/Product/Product.aspx?Item=N82E16820211052 Thanks <3
Sep 10, 2008 #2 Q QHalo 2[H]4U Joined Sep 30, 2002 Messages 3,432 What about this one!? http://www.newegg.com/Product/Produ...rgains&cm_mmc=AFC-Bensbargains-_-NA-_-NA-_-NA
Sep 10, 2008 #3 M msabo Gawd Joined Jun 23, 2008 Messages 632 Of the three, the A-DATA is best value. However for raw performance, suggest you look into the Memina Rocket.
Sep 11, 2008 #4 D DonDon [H]ard|Gawd Joined Sep 17, 2000 Messages 1,584 What do you want to use it for?
