I'm torn between the LSI 9261-8i and the 3ware 9750-8i. I've used 3ware a lot myself and now LSI bought them.. These cards are very similar but, are there ANY differences? Speed/performance/commandline tools, etc.
I plan on using it in a flavor of Linux. I do not plan on using the BBU for this setup as write speeds will not be an issue and write caching is not important for me. Read speed is what it's all going to be about.
If anyone has other RAID card flavors; feel free to throw in the options. I do require RAID 6. Preferred 6g SATA in the end just for the overall benefits of the controller setup even with 3g drives. But I do want to make sure it has a fast array rebuild (if possible), hot-spare support. Online raid migration and expansion capabilities... SAS expandability if I ever get a nice backplane to go above 8 drives... etc. I do not need SSD capability since I'm going to huge storage (12TB usable space with 2TB drives x8 in RAID 6)... But it might be nice in a tie otherwise.
I went to the 9750 due to my familiarity with them and then found the LSI flavor (and it's $20 cheaper! Bonus...)... Anyone have more that I'm missing? I have no direct experience with LSI.
EDIT: Updated requirement information and current suspect lists;
Right now it seems my options are limited to: (in no particular order)
- Raid 6
- 2 x SFF-8087 mini-SAS
- SATA 6Gb/s
- $500 limit
- HighPoint RocketRAID 4320 (not high on my list)
- 3ware Internal 9750-8i (current most likely suspect)
- LSI MegaRAID 9261-8i (or one of a number of other flavors depending where you want the SAS plugs. I think end-of-card is fine for me.)
