Help me pick out my new system please.
extreme
Hey guys been out of the loop for a while and well i think its time for a new system. Well after doing some looking around on the fourms and what not i decided to go with a DFI bored and a AMD X2. Here is what i picked out so far. I have all the drives im going to use at home. Lead me in the right path
Western Digital Raptor WD740GD 74GB 10,000 RPM Serial ATA150 x2
DFI LANPARTY nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD
BFG Tech BFGR78256GTXOC Geforce 7800GTX 256MB GDDR3 PCI Express x16
Antec NeoPower ATX 480W Power Supply
THERMALRIGHT XP-120 Heatsink
Panasonic Panaflo FBA12G 12U1C 120mm Hydro Wave Case Cooling Fan
OCZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model
OCZ4001024ELDCPER2-K
AMD Athlon 64 X2 4600+ Manchester 1GHz FSB Socket 939 Dual Core Processor Model ADA4600BVBOX
Thanks for the help
Thats a fine setup. Do you plan on overclocking at all? If you been out of the loop for a while, I would maybe get the A8N-SLi instead; requires less tweaking and is rock stable.
Ya im going to overclock it. As in out of loop i mean like what the new and best hardware is. I now how to over clock, have several setups with intel and watercooling. Just AMD, not to sure about it. Thanks for the help
i would get a more beefy psu. will be cutting it close with 480 in my opinion. especially if you decide later to go sli and over clock.
Ya im defintly going to get a bigger psu, cause i when i get the cash im gonna go SLI and i am for sure overclocking. Thanks for the help :)
I don't know nothin', but I tend to think people overpurchase PS'es. You can get the stats on each device to see the peak load. I don't think you'll need more than 480W.
FWIW,
BoB
480 should be plenty for a non-sli rig.
overall it looks to be a well-balanced system.
only thing i would consider diffrent-- is the ram-- i am sold on the G-skill tccd's !
i did run my 6800gt's(SLI) a few times with 450w and once in a while i would get the low-volts on startup-warning- with one card--never a problem. :eek:
i would get an sli certified psu just to be safe. no telling what the power requirements are gonna be down the road . i believe nvidia recommends at least 500watts for there new cards for sli mode. i would rather have to much power then not enough. :D
For reality check on PSUs goto DFI-street.com
Do NOT listen to all the self acclaimed experts out there.
The official requirement on PSU from DFI is 480W 24 pin native and this is for NON-sli setups. (and this is brand PSUs with high Amparage on the 12V lines)
And to the ppl there that says otherwise. Are U guarateeing that it will work with what U recommend i.e. will U reimburse the extra costs if it doesn't work. If not STFU!!
PC Power and Cooling makes good PSUs, provided you can afford them. I have one of their older 510s in my box, which runs not only my new A8N-E but five hard disk drives (including two Raptors), a 6800GT and some other stuff. And it's 20-pin. My board is 24. So I can personally recommend it. You should be fine with their 510 SLI or (!) the new 850, if you have that kind of money.
If it's an condolence I love my 4600+ manchester. It runs stably at 2.5ghz and runs decent but hot at 2.7. My ram is corsair xms 1.5g though. I think my ram is 333mhz.
