Help me pick my next case.
Copyright
Having a hard time picking my next case. I am selling one system and taking the drives out to show into my next setup. I need plenty of room with plenty of cooling. I also want it as quiet as possible. I like the clean look of Lian Li cases. I know I can get a blow hole added for extra cooling and run some under volted slipstream fans. I do have to keep my 4870x2 and drives cool along with an overclocked Quad.. thanks for any advice!
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=204&products_id=23786
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=204&products_id=22334
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=104&products_id=23947
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=204&products_id=23758
I'm really really liking the A77B...
Heck, I'd probably use that over my current V2000...
CM Cosmos 1000.
+1 for the A77B, I got it last week, just been to scared of chopping it. the only thing I did was paint the inside black. It can fit the new graphics cards for sure. I'm going to put a 3x120mm fan/rad setup at the top once i get over the fact that I'm going to mod a $250+ case.
The A77's clean exterior give it a look of sophistication yet the vented drive bay covers hints at its potentially outrageous air flow. The other candidates look very nice but I find that doors (most of the time with main computers) get in the way.
I would got for the A77, but in silver. That way I could give it a mirror polish, but going with the black one, blemishes would be less evident if the case was kept stock.
I'd also look at Silverstone. I just picked up a TJ-09 and I'm quite pleased with it.
Not a fan of the Cosmos or Antec 300... without thinking about price it comes down to the A77 and A20. I am really leaning towards the A20. I will never use more then 6 drives.
If money isn't an issue, I'd probably go with the A20. that thing is sexy as hell. :D it looks like cooling from the front won't be as good, but the "multi-zone" cooling concept sounds pretty awesome. And just guessing, but it's probably quieter with the fans inside the case (and behind a door) instead of in front with no door.
Yeah, the door does help a lot. I actually like the doors for this reason. Also I plan on adding another 120mm fan in the top bay area to blow in.. this should help the cooling.
