Help me pick my GPU...or dont
TypeRazor
The "dont" part in relation to waiting for the HD8xxx or 7xx series and see what they bring to the table.
5 monitors total:
1 36" TV 1920x1080 HDMI from Z77
1 30" monitor 2560x1600 HDMI/DP?
2 20" monitor 1600x1200 HDMI/DVI
1 22" monitor 1920x1080 HDMI/DVI
2560x1600 gaming with medium settings 4/x4 area is what im aiming for
lowest possible heat/noise
mITX case
The big dilemma comes down the port requirements im finding, unless someone finally releases a display port hub...that would be nice
Going with a Z77 chipset will most likely be required from what Ive seen so far.
TV HDMI (from Z77)
30" DP
20" (2x) DVI
22" HDMI
no monitors or parts have been purchased and there is no deadline to finish the build
thanks
1600 medium settings with AA would still require a GTX 670/80 or 79XX card i say get the 7970 right now
EVGA sells a usb3 to 1080p hdmi converter. May not be hdmi, but it converts usb3 to 1080p. GL
7970 imho
Im thinking about just getting a 7770, game at something below native resolution and just waiting
unless I can get a good deal on a 7970.
thanks everyone
