Help me pick my Christmas upgrades
PopeKevinI
Current system:
Thermaltake Tsunami case (silver, no window)
Antec 480W TrueBlue power supply
Abit IC7 Max III (AGP, socket 478)
2.2 Ghz P4, 400 Mhz FSB
512 MB PC2100 RAM (Micron)
ATI Radeon X850 Pro
Adaptec 1200A ATA RAID controller
2 x 120 GB Seagate
1 x 80 GB WD SE
LiteOn DVD+-RW
I'm mostly looking to max out performance on this motherboard until I gut the system in a year or two. I know it's an odd mismatch of components...the CPU was a freebie from Intel that never got replaced despite my best intentions, and the RAM was what I had on hand when I lost my 1 GB.
Looking to spend around $400-450 and get the best performance I can. I'd love to go with 2 GB of RAM, but that's a luxury I can do without if I have to.
Bona Fide said:
Good RAM for the money. Now you'll have 1.5GB total.
The Micron is coming out. It's cheap PC2100. Pulling the Micron will get me one step closer to a decent Linux box. Besides, this mobo supports dual channel ram, might as well make use of it.
Speaking of which...anyone know if I could dual channel four ram modules, or does it only work with two? I've heard conflicting reports on that.
I would most def do ballistix pc 3200 512 x 2 , you can always use these when you upgrade, and a cpu upgrade 2.8 or 3.0. Save the rest when you rehaul system.
OR
AMD64 3k+ and the Ballistix plus a AGP socket 939 mobo. You can OC this chip to at least 2.4. :D
Chip 150
Ballistix 130
Mobo your choosing up to 100 and have $20 left over.
List of mobos
I'm not sure but I believe Asrock is division of Asus... it is Dual core ready and supports agp and pci express and seems real future proof. Make sure you do your HW on it htough.
You can also try and wait for one of the Opti's everyone has been talking about.
OR
Chip 150
Ballistix 130
List of mobos
I'm holding off doing a total system upgrade for now. Few reasons:
1) Windows Vista. I want to install it on a fresh build.
2) PCIe. The X850 is going to be my last AGP card.
3) DDR2 (or whatever follows it). I don't want my next build to bottleneck on an aging technology.
4) I have four Socket 478 mobos (two with bad AGP slots, accursed Soyo), and currently one CPU. I might as well pick up another CPU so I can make use of what I have. Some time next year I'm going to pick up a couple more 2.x P4s and some memory so I can build my wife a decent system and put together a couple of Linux boxes. Might even have enough extra power to join the [H]orde then :D
But yeah, my next build will likely be AMD. I've only used Intel as long as I have because I got a free socket 478 mobo/CPU from them, and have never had the money to completely gut the system and do a new build.
2 x 1GB DDR 400 Crucial Value Ram -220$ ish les then that prob
And a P4 Processor up to 200$
XP 90 HSF :)
4 sticks will work in dual channel, but it'll increase latency a little bit, nothing noticeable
I'm not a serious performance hound anyway. I don't care about my 3DMark scores or anything like that...I just want 30+ fps on all my games at the highest quality I can manage. And I seriously doubt a slight increase in latency is going to cause me to lose several fps.
Like I said, nothing noticeable so you'll be fine. Let us know what you end up doing :)
PopeKevinI
I can't stand that company. I will NEVER buy a product from them again. Trash and liars. I never recieved my rebates and I called them again and still haven't received.
MC FLMJIG said:
PopeKevinI
Yeah, I'll never touch Soyo again. Their Dragon boards were well-reviewed. What the reviewers couldn't have known was that the AGP ports get flaky after 12-14 months. I bought a second board because Soyo told me it would retain my RAID array...it didn't. Bye bye data. That board suffered the same problems: just after the warranty ran out, the video drivers crashed constantly. It even killed my GFFX5200. The only way to get the system to work was use an old PCI video card.
Soyo denied there was any problem with their boards and told me I must be doing something wrong.
Soo...
1) Soyo made a crappy product.
2) Soyo didn't even know how their on-board RAID controllers worked.
3) Soyo's board killed my video card.
4) Soyo blamed me.
LOL, not to you but the whole thing. I can't stand them. I heard they ripped many people off with some rebates they had. The products weren't even that good as well. NEVER again.
We need a mobo guide of some sort. There are memry guides, psu guides we need a mobo guide.
Well, the thing is that the mobos performed exactly as expected, right up until the AGP ports failed more than a year after I bought them. A mobo guide would say: "Great board, good features, tests great."
A year later, posts would start showing up: "Be sure to get a PCI vidcard, because your AGP port won't last much longer than your warranty."
Okay...think I've got it:
P4 3.0E: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80661-1
2 x Corsair TwinX 1 GB (2x512) packs: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80097-17
Sound good? Could I do better with the same money ($428.90 shipped)?
Then my 2.2 Ghz can go back in the mobo it came with and into a new PC to replace my wife's aging eMachine (yay she's finally letting me get rid of it). Some time around March I'll pick up a couple of cheap S478 processors to go in those Soyo boards and another 512 MB stick of RAM to get me two decent test systems.
So...for somewhere around $600, I'll have essentially maxed out my current motherboard and built three more from existing parts.
And I'll have the fastest system on the block again for a while :D
edit: one reason for the 4x512 MB memory is to be able to more effectively part it out later, when this system gets replaced. This way I can split a pair up if I want to to get the most of out my old hardware.
