Help me Pick (Building New System) Dual or Quad
WJC05
Just want to give a little background information.
First my current PC:
AMD Athlon 64 X2 S939 3800 (currently running 2.6Ghz)
ASUS A8N-SLI Premium ( love this motherboard to death)
2 X 1GB Mushkin PC-3200 DDR Ram
2 X 500GB SATA HD
1 X 320GB SATA HD
Allied 550watt PS
Nvidia Geforce 8500GT
32" Insiginia HDTV/Monitor
This is the computer I have now which I built myself about two years, maybe a little more ago. The only thing that isnt original is the Video Card, Monitor, and HDs.
Im now starting to get into HD movies in 264 format in 720p and it doesnt really work too well trying to watch a Movie in HD in 264 format (Sometimes it even has trouble playing 720 files with nothing else going on), while Im downloading at 8mb/sec, while using par files to fix downloads and unraring files that Ive just fixed using Quick Par. I also like to use nero vision to encode Divx movies onto DVD for my fiance and with nothing else going on, two passes takes about 1hr 30mins to 2hours.
I do want to mention that I play No games.. Last game I played was Sims 2 and that was probably a year ago.
Okay so here is to the real question. I want to be able to do all of the above at once and not be slowed down. Im currently running windows vista ultimate. Dont really want to go to 64 unless I have to...
Im looking between two processors and dont care to overclock them to their limits with the best HSF I can get..
Intel C2D E6850
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115028
or
Intel Core 2 Quad Q6600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
Could you please help me decide and tell me why one is better than the other? I mean I know one has 4 cores, but is it faster with the clock of the Dual?
Also whats the best motherboard for these guys? Does Asus make a similar motherboard to the one I have in my system now for these guys? I love my motherboard now :D
i would go with the quad because the cost isn't a big factor between the 2 and the quads are going to be utilized more in the future and any kind of video editing or converting the quads perform better, and with high def soon to be the standard video files are going to be larger than ever
Will either of these processors handle these jobs all going at once? It would be real nice to be able to get all of these processes going at the same time :D
You'll be better off with the quad if you want such multitasking performance.
This will help you determine whether or not the quadcore is for you...
http://www23.tomshardware.com/cpu_2007.html?modelx=33&model1=872&model2=871&chart=418
Just so you and everyone else knows... with the E6850, you're paying $100 for 333Mhz over the E6750. You could get that 333Mhz for free with a simple yet minor OC on the E6750 -- all you need to change is one BIOS setting, lol. Don't worry, the limit of both of the CPUs is the same, around 4Ghz. But like I said, you're better off with the Q6600, OC'd or not.
