Help me pick an upgrade path....
AMD_RULES
Which is better performing?
AMD Athlon 64 X2 6000+
with ASUS M2N-SLI Deluxe
or
Intel Core 2 Duo E6600
ASUS P5N32-E SLI Plus
I am not looking into overclocking at all. I think the AMD route might be better and cheaper for me as well....
AMD is no longer cheaper than the Intel route now, that 6000+ chip under-performs in almost all aspects and costs more than the Intel chip will in a couple of days time.
the Core 2 Duo E6000 is around $230 ~ $240 retail now. Price competitive with the 6000+, and performance wise on par-or greater in most benchmarks.
If you really want AMD, as your name suggests, I don't think it would be such a waste of money if you're not overclocking. Prices are very competetive now, so its not as much a waste of money as before. :p With that said, your two motherboards are incomparable. The Intel counterpart to the M2N-SLI is the P5N-E SLI. So, the AMD route isn't better nor cheaper... but its still not a bad option.
