Help me pick a wall mount
DarkStar02
Apparently monoprice wall mounts have flimsy metal anchors and I'm not trying to have my TV fall 6 feet to the ground. Can somebody link me to an inexpensive, decent, tilting wall mount? (Swivel is a bonus, but I want it to at least tilt).
This one is $24.99. Uhmm not sure I would put a 30" on it though. I was looking at it for our kitchen 20" LCD, but the spec does say 30" 33lb.
http://www.ikea.com/us/en/catalog/products/40105364
That's about a cheap as your going to get. I wish they mentioned how long the arm was. :(
This is even cheaper, in fact this is just about the best place to get any TV or Monitor mount that I have come across.
Forgot to mention it's a 37"er. I read a review saying that the 37" capable brackets are huge and is highly visible. They recommended to go a ~36" bracket if you have a 37" LCD but they didn't mention if they did it or if it even worked for them. Anybody have any experience with this?
I've bought several wall mounts for my plasma and LCD TV's from this guy on Ebay. Here's one: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230182520458&ru=http%3A%2F%2Fsearch.ebay.com%3A80%2Fsearch%2Fsearch.dll%3Fcgiurl%3Dhttp%253A%252F%252Fcgi.ebay.com%252Fws%252F%26fkr%3D1%26from%3DR8%26satitle%3D230182520458%26category0%3D%26fvi%3D1 It's item # 230182520458 if the link doesn't work. He has several different types but this one tilts and doesn't stick out much and seems to be built solid.
