Help me pick a new Case!
pc1x1
Currently I am using a Coolermaster Wavemaster, awesome case, however I find that I need more space inside.
I mostly looked at the Cooler Master Stacker, and Cosmos line, and the Thermaltake Armor Series.
I am looking for any case, that can hold 2 or 3 water loops each with a 3x 120mm Radiator, one can be external, but if it can be fit inside, its better. I am using one loop right now, and its practically impossible to add anymore. I need to water cool, CPU, and possibly 3 GPUs.
I need space for 2-4 hardrives.
as well as space for 3 GPUs, aka Tri 9800GTX SLI, though exactly which gpu, I am not sure yet.
and I want a window view on the side, so I can see if anything ever leaked, etc.
The rest is just standard stuff.
Black or Silver color.
My case tastes are normally Cooler Master, Lian Li, etc, I like professionals looking cases, and I prefer steel or aluminum frames.
I checked out Newegg, and SVC thus far, but looking for more input.
I don't want to pass $400 USD if possible.
Also like hiding the drives, ie a little door on the front of the case case, if possible.
Any suggestions?
I don't think that you could go wrong with any of the full tower lian li cases, but IMO the V2010 and A77 look the nicest to me.
Cooler master 590/690
If you have a local Fry's, you can check and see if they still have the stacker 830 SE's. They're going for $100
Also, the rocketfish full tower cases are supposedly in clearance at best buy, though ymmv. These towers are rebranded Lian Li's.
I don't really know much about Lian Li's, but they look great!
I like the stacker, there is no fry's unfortunately in Florida, at least to my knowledge, perhaps someone can pick one up for me :D. Is there a windows available for this model, I am water cooled, so losing fans isn't a problem.
how about lian li cases?
the new v series just came out
check out the lian li v2110, v2010, P80, and A77
all good candidates for your build:D
