Just got an E8400 (wolfdale core).
First off, coretemp is NOT reading the correct temp. Next, Prime95 is either throwing errors, or crashing after about 20 sec of use. Folding @ Home ran w/o crashing. 3dMark06 ran well for 2 passes, and crashed on a third. Here are the settings:
CPU Clock Ratio: 9x
CPU Host Frequency: 400
PCI Express Frequency: 100
CIA2: Disabled
Performance Enhance: Standard
System Memory Multiplier: 2.00
DRAM Timing Selectable: Auto
DDR2 Voltage control: +0.1V (memory likes 1.9V)
PCI-E OverVoltage Control: Normal
FSB OverVoltage Control: Normal
CPU Voltage Control: 1.2375
Normal CPU Vcore: 1.2250
What do you think I should change? Obviously it's not totally stable.
CPU Clock Ratio: 9x
CIA2: Disabled
