Help Me Overclock A64
matt00926
A64 2800 + Retail HSF
Antec true 380w
Corsair 2 x 256 pc3200 XL (2-2-2-5-1T @ 2.8v)
Abit nf8 nforce 3 ultra 250gb
Sadly the max ram voltage on this board is 2.8v :( . GG Abit. Anyway ive been having some troubles.
With HTT @ 245 and ram divider set to max 166 (i dont know why but abit nf8 doesnt have fraction dividers) I can reach 2.2 ghz with ram @ 200 mhz
With HTT @ 267 and ram divider set to max 133 i can reach 2.4 ghz, but then ram only runs @ 171 mhz
I tried leaving the cpu alone, and the max i can put my ram to is 209 mhz, giving me 1870 mhz , so about a 7-8 % performance increase total.
Does anyone have experience with this board, and am i extremely limited because i only have pc3200? Im relatively new to A64, and also my cooling is adequate so that is not my limiting factor.
Also to mention i ran the 2.4 ghz at stock voltage and it was prime stable and other various tools i used to test.
This is what im currently running,
Current Setup:
Sorry for the long thread, id just like to max out the performance of my system. And as probably obvious i am a newb :D .
I would suggest you use the search tool before posting.
There are several threads and stickies that will guide you thru the neccesary steps to overclock a A64.
A user name (cf)Eclipse can help you best.
He's the president of the socket 939 club :D
