Help me out...
did you try to make a new bookmark in ie, firefox etc. then cut/paste said code into it?
and did you try to modify it from what is on the page?
Code:
javascript:document.vbform.message.value=document.vbform.message.value + ' [URL=http://www.hardfolding.com?go=38&id=119][IMG]http://www.hardfolding.com/ftag1.php/mem/119.png[/IMG][/URL]'; document.vbform.submit(); halt;
Using IE or Firefox? Either way, basically you want to make a bookmark with this ^ as the "url". We can probably give better directions if you tell us which browser.
FireFox...I have gotten Xeno's to work this way before, however when I modified the link, it doesn't work any longer.
What's your username? Is this it:
If you are using the javascript version you need to make a bookmark out of the javascript code. When you want to submit a post, you click on that bookmark and it will insert the proper code for you for your badge. (I just pasted the URL code in here for your badge).
Do you have the single quotes before and after it right? Check out the JS console (Tools -> Javascript Console) and see what error it gets when you click on the bookmark.
Code:
javascript:document.vbform.message.value=document.vbform.message.value + '[CENTER][color=#222222 - Fold [H]ard - [/COLOR][URL=http://www.hardfolding.com?go=38&id=285][IMG]http://www.hardfolding.com/ftag1.php/mem/285.png[/IMG][/URL][color=#222222] - Or go [H]ome - /COLOR]/CENTER]'; document.vbform.submit(); halt;
is mine... broken down..
Code:
'CENTER]color=#222222] - Fold [H]ard - [/COLOR]
[/URL]color=#222222] - Or go [H]ome - /COLOR]/CENTER]'
if you want to edit linkage etc you have to do it within the ' 's like they said.. and then remove all spaces/breaks that you have added
test
119
when I put this in the quotes:
Code:
it doesn't work
Clickable, it is not....
Keep on Folding!!
edit.... now it is lol
the code to use is at the bottom of your personal stats page. Keep calm Moose, don't wanna go on a drunken rage now. :D
edit: looks like you got it.
Why not? :D
I love that pic!
I figured out that I had a space where there should be none and that was causing the problem. :eek:
