So I've got the rig in the sig, with a CoolerMaster Hyper TX3 cpu cooler:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103064
Till, now, I've been running it with just one fan, in a pull configuration, blowing downward. But I want to OC my CPU, so I need a bit more cooling. I bought a second fan to run a push pull configuration. But I'm not sure if I should orient the fans so that they blow to the top of the case, or blow downward. There's not much room either way.
Unfortunately, I can't orient the fan so that it blows backward (toward the back exhaust fan), which is what I think would be best.
Any thoughts?
My case has 2 intake fans and one exhaust fan. It has a mesh cutout on the side of the case that I've removed to take this picture:
Any thoughts?
