So I am making a cube, a relatively small cube, aiming for 11"
It's gonna be made of acrylic and im shooting for this style... When i saw the two way mirror thing I kinda fell in love with it. Its just really cool.. anyways.
I made a pretty rough design in sketchup and was just wondering if you guys can give me suggestions and comments, etc.
Im not sure about the front 120's and the 80 intake. I think the holes and potentially a grille of some sorts would take away from the mirror stlye of the case. I don't mind putting the 120's on top, but that still leaves the problem of the 80mm. Suggestions?
Im also worried about the power supply. Right now I have the 600watt coolmax modular (cu-600t i think). The psu has no fan for exaust (just the whole back is grille-ish) and it has a 120mm intake. On normal cases the intake would be sucking air in, from right around the cpu. With my new design, the only thing I could do is have the case rised a bit, and have the fan pull air in from underneath the case
Can you guys give me suggestions and potential probelms I have with my design.
My specs will be:
Some matx board (hopefully the dfi 939 that should be released soon)
a64 3500 air cooled by a vapochill micro extreme performance
currently 512x2 of ocz extreme gamer pc3500 (might upgrade)
connect3d x850xtpe (may change the stock cooler with that of a x800 series or x850pro (something single slot))
I have a 36gb raptor, a 160gb sataII hitachi, and a 120gb wd ide drive.
That was a long post but all help is greatly appreciated
Thanks
My specs will be:
Thanks
