help me oc my athlon64!
7718
Whats up with HTT? why are my temps so low? I am so very curious.
So i got this new mb (epox EP-9NDA3J) , new cpu (3000+ athlon64) , and a XP-90 to cool it with.. And their are alot of options in the bios, HTT multiplier, memory speed ect. I've found that if i set my memory to 133, and FSB to 260 i get 167mhz memory w/cpu @ 2399mhz. It seems to run windows fine so far, what i am asking for is basicly , what are some good programs to test/burn in the machine? I'm using cpu z currently to monitor speeds, ntune doesn't want to monitor my sys, it says my motherboard isn't supported.
Any suggestions would be cool, just got this stuff from newegg this morning, and its awesome. so far the cpu runs around 80F, and the chipset is reporting 70F. Thats not very different from my previous 2.2ghz 1700+ temps.
code on the cpu was
ada3000dik4bi
cbbid0451epmw
6174239a50559
right on thanks man. On my own i got it to 2609mhz, mem at 186mhz, HTT 3x 870mhz. 1.5volts 88F.
Make sure you Prime95 that monster. Just because it's in Windows doesn't mean it's doing what it's supposed to.
