Help me OC/MOD my RADEON!
danielssbm
well its around the 9700pro speeds at stock and i think the core can go more up. I was thinking of buying a VGA silencer and some ramsinks. Which ramsinks would be good to fit the L-shaped memory on my 9500. BTW should i buy some AS5 to go with it?
danielssbm is online now Edit/Delete Message
go for some AS5, a vga silencer, and some frozencpu or OCZ copper ramsinks.
and you might need to remove the shim.
