help me mod my radeon 9800 pro
Stugots
http://www.sapphiretech.com/vga/9800proatl.asp
thats the card im going to be getting in the mail in a few days. im not an ati person, this is my first ati card, so what sorts of mods can be done to this card. i heard they can be flashed to 9800xt's. im going to be removing the heatsink and hooking it up to my koolance so cooling shouldnt be a problem.
u can stick a vga silencer for higher oc's, u can oc, u can flash bios if u got the right core, etc. have fun with it its a good card
where do i get the files to flash it to a 9800xt, and how can i tell if its the right core short of removing the heatsink and looking.
Sometimes you'll get dud cards as far as OCing goes. Mine is an R360, that I've strapped a AMD aluminum heatsink to with an 80mm Panaflo fan blowing on that and I can't really get higher than 412 without artifacting in 3DMark03. 434 is where it can go without freezing, artifacting ignored.
from what ive read its recommended that before you flash it to an XT that you overclock it to XT speeds to see if the ram and core can handle XT speeds. so ill probobly try that. and if i cant run it as an XP, its still a hella better card than my 5600u.
