Help me improve my latest build!
Thrmo
Ferquently Watching HD videos online, Gaming (COD:BO, BF:BC2, Star Wars: The Old Republic amd Diablo 3 when they come out. Other FPS I'm sure)
$700 - $750 without shipping. But We do have Amazon Prime so I would prefer Amazon or Newegg.
3) Where do you live?
Texas
Motherboard, Ram, PSU, CPU, Replacement exhaust fans for my Antec 300
HHD (WD5000AAKS), XFX HD 6970, Cooler Master Hyper 212+, Antec 300 case, Optical Drive (LG DVD GH22NS30)
6) Will you be overclocking?
Yes, but not too agressively
21.5" LG W2240T at 1920 x 1080
Once the P67 motherboards are availible again
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Crossfire Support mostly, not sure of anything else that is mission critical.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 7 Home Premium 64 bit
I plan to add a second HD 6970 at some time in the future, but as of now these are the parts I'm considering.
Mobo - $150? -ASRock P67 Extreme
RAM - $105 - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
CPU - $129 - Intel Core i5 2500k
PSU - $150 after rebate - Corsair HX 850
Those are the biggies, I'll also be getting two fans to replace the exhaust fans in my Antec 300 and some AS 5.
Top Fan - $15 - AeroCool Shark 140mm
Rear Fan - $13 - AeroCool Shark 120mm
Thermal Grease - $12 - Arctic Silver 5 kit
NewEgg has the processor/motherboard combos that beat Amazon's prices, even with Amazon Prime.
I'm somewhat against AS5 due to its curing time; I recommend an equally capable TIM without any curing time like the Arctic Cooling MX-4. (That said, I prefer using the Arctic Clean over isopropyl alcohol.)
If you're going with Sandy Bridge, I recommend getting a board with more overclocking features and a better warranty than ASRock. Asus (which is ASRock's parent brand), Gigabyte, and MSI make good boards that aren't that much more expensive.
As for case fans, go with some cheaper Yate Loons. (However, they may not be available at Amazon, and I know that NewEgg doesn't stock them.)
