Help me identify this DVI port
strat4812
What port is this? It is an old radeon 7000 card taken out of an old dell, my vga to dvi adapters do not fit on it,
building a new computer for someone and rather than get a new monitor I figured I could get an adapter that goes from this to standard dvi.
http://en.wikipedia.org/wiki/Digital_Visual_Interface
In the article I link above, note that the DVI-I socket (which is what I thought this was at first) has 8 square holes to the right, while the M1-DA socket has 10.
"M1-DA connectors are sometimes labeled as DVI-M1; they are used for the VESA Enhanced Video Connector and VESA Plug and Display schemes." The picture is also titled "DVI M1-DA Dual-Link + USB".
While I've never heard of these before, I think these cables on monoprice.com are the ones you need:
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10238
Adapters seem to be $15-20. At that price might as well get a new card, since newer stuff will be better than a Radeon 7000. Also, if you're building a new computer, why not just use integrated. It'll probably be much better than the Radeon 7000.
I wasnt going to use the old radeon card in the new computer, the monitor that they have has the same end on it, so rather than buy a new monitor, i just wanted an adapter
