Help me identify a case
GotBass?
I bought a used PC and it came in a completely unbranded case. It's definitely not a high-en case, but it appears to be decently designed: tooless drive bays and PCI slots, black interior, holes for cable management, large opening behind the cpu, rubber vibration dampening for the 3.5" drives, dust filters 5.25" drives bays as well as the front fans, etc. It came with six 120mm fans (unbranded): 3 blue LED fans and 3 black fans. It's built out of steel. Here are some pics:
Anyone knows the brand and model?
Looks like an unbranded Cooler Master Elite or Centurion that has an upgraded HDD cage..
It's indeed similar to some Cooler Master Elite and Centurion cases. But I couldn't find one that has the exact same interior layout.
The internal design also reminds me of my Fractal Design Define R3. The overall layout, the drive trays and the bottom fan mount are similar. It also has larger case feet in the front and smaller ones in the back, like the Define R3.
