- Jan 5, 2006
Hi all!
So my only programming was done on a Tandy Coco and that was just silly Basic programs from books and the usual Hello World on python as my second failed attempt at programming!
But now I want to do this for real. Within my company, fellow employees that had some knowledge in programming doing simple things have had better chances moving up so while I know it will take a while to learn, the sooner I start the better.
So I decided to go with JAVA first instead of C# which both were recommended by a software engineer friend of mine (not a coworker).
My reason for JAVA is the possibility of programming android later on but then again, by the time I learn maybe there will be no Android LOL
So, I installed JDK, JRE and Eclipse but I am not sure what books and online resources are best to start learning.
I have seen some recommendations but usually are like old books so not sure if newer ones are better and just I cant find the right ones etc.
Any recommendations will be appreciated!
Regards
Regards
