I was wondering u all geeks can help me here. I need fastest memory out there from OCZ platinum or gold series. Need help to find right timing. I am going to use them on E6600 with Gagabiyte DS-965 M/B. Money is not an issue. I was looking at following from Newegg. I am not sure which is faster between these two.
OCZ Platinum 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Unbuffered Dual Channel Kit System Memory Model OCZ2P10002GK - Retail
Cas Latency: 5
Features: Platinum XTC
Heat Spreader: Yes
Manufacturer Warranty: Lifetime
Timing: 5-5-5-15
Model #: OCZ2P10002GK
Item #: N82E16820227091
OR
OCZ Gold 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Unbuffered Dual Channel Kit System Memory Model OCZ2G10002GK - Retail
Cas Latency: 5
Features: Gold XTC
Heat Spreader: Yes
Timing: 5-6-6-15
Model #: OCZ2G10002GK
Item #: N82E16820227090
Cas Latency: 5
Heat Spreader: Yes
Timing: 5-5-5-15
OR
Cas Latency: 5
Features: Gold XTC
Heat Spreader: Yes
Timing: 5-6-6-15
