help me get a stable 4ghz oc?
skuzzzzy
ok so another user on overclock.net forums has the same motherboard and cpu as me, so he's been trying to help me oc my cpu to 4ghz. i cannot seem to get it stable, within 1:40-1:50 running linx with max memory it errors and stops.
ive been using higher vcore then him because i was going to work my way down to see what the lowest vcore i could use that was stable.
heres some pictures of his settings then ill post what i used, so maybe you can help me figure out what to try.
http://img13.imageshack.us/i/dscf3757o.jpg/
http://img841.imageshack.us/i/dscf3758.jpg/
http://img237.imageshack.us/i/dscf3760.jpg/
http://img210.imageshack.us/i/dscf3762v.jpg/
http://img185.imageshack.us/i/dscf3763.jpg/
http://img830.imageshack.us/i/linxmaxtemp.jpg/
i used same exact settings but i used, 1.38v on dram due to me having 1.35v ram (when i enter 1.35v to switchs to 1.38), and thats not the culprit because when i reset bios to stock and ram to 1.38 it ran linx fine.
i also use 1.32v vcore, 1.30v cpu vtt, everything else is identical. after that i tried "high vdroop", 1.35v vcore, 1.32v vtt and after loading windows i opened linx and bsod'd. after that i reset bios and still kept bsoding after starting the computer with default settings. after clearing cmos it's working again, so thats where i am at the moment.
my specs are,
intel i7 860 cpu
msi p55 gd80 motherboard
g.skill eco series 1600mhz ram
