Help me find my hardware failure
Cali3350
I was pushing my system earlier in an attempt to discover its maximum overclock. In the process I pushed the computer just a little too hard and it refused to boot. No problem - i just cleared the CMOS and am back up and running!
The problem is Windows would no longer load. It would just STOP while the splash screen came up with the status bar. It would stop functioning. Safe Mode worked fine but nothing else, so i eventually decided to just reformat. The problem is now after reformatting Windows Installation is getting stuck at the Installing Devices Screen! It just freezes, mouse hard locks and nothing works. I have a hardware failure somewhere - though i have no idea where.
It would always stop loading windows at the same place, and freezes during a new installation at the same place. Its a single piece of hardware though im stuck at what it is. Ive removed all PCI devices - i only have my Video card in, and my CD-Drive and HDD. Memtest can run forever, I have everything at stock. I need ideas guys as ive COMPLETELY hit a brock wall.
Thanks guys, i really appreciate any help you can give here.
Not 100% sure, but you may have damaged your hard drive with that high overclock.
Check the BIOS to make sure the default settings you restored are actually correct. Also make sure that all the speeds it is detecting are correct too.
It sounds like it is your hard drive. But to make sure, run everything at stock settings and if it is still doing it, take everything except the processor and motherboard. Take out the cards, memory, detach all drives. If your system boots and fails (error code beeps), that is ok. Now add the video card, you'll get an error, but at least you know your video card works. Now add the memory, if it says there is no boot disk, good, you are ok so far. Add a known good drive, it if boots up, you know the cable and hard drive channel is ok. Now, attack the optical drive, if everything boots fine, good. Now attach drive in question, try reinstalling the OS, if it fails again, I'd say the drive is bad.
Run memtest for a couple hours. Or try to load a Linux Live CD.
