Hello,
I'm looking for a TV tuner solution which can read both HD and SD signals from a Comcast digital cable box, and also a satellite signal from a DirecTV box. I would prefer the tuner to be
a: integrated into the PC
b: a single tuner card
but can also consider getting two tuners if necessary. Mostly, I'm concerned for its ability to do the following:
Display a TV guide such as the one coming from Comcast
Be able to display & record shows from both the cable feed and the DirecTV feed
Actually work as intended (seems to be a problem from a lot of the reviews I'm reading).
Could anyone give me a suggestion? I was looking at the Hauppauge WinTV-HVR-2250; would that suit my needs? A google search shows some problems getting it set up with an HD signal, but the problem seems to be a year old. Has anyone got an HD TV tuner working? Also, is it worth it to wait for the Colossus PVR mentioned in another post on here?
Thanks!
Edit: The comcast box has only HDMI, ethernet, and 1394 outputs. Does that mean the colossus is my only option?
Thanks!
