help me diagnose my BSOD
stain.
I had a BSOD, and it started a few days ago.
On one it stated an error with how it connected to the ip(?) or established the ip.
I think my memory might be at fault due to me having one stick go bad for 2 days, then start to work again.
on aonother BSOD it stated a memory error. I haven't had my system up and stable (at a mild oc) for the past 2 days and I know I didn't overheat/fry my cpu, I have had issues with the mobo (keyboard controller is buggy), and it seems as tho I loose the internet connection (lagg out) for about 2 minutes every so often.
I'll reply with more when I get to work.
Can you post the stop error? That would help....but if you are having memory problems, that is definitely where you should start..
I think it's dominately memory.. but I did just recently have a storm close by. My router isn't picking up my computer (network light is off) when everything is connected. It randomly happens. stupid I know.
Should I RMA the mobo/ram, and get a new router?
I would recommend running Memtest first to verify that your ram is bad... let it run for at least 12 hours, and see what it comes back with. I think you'll find that bad ram is you problem...
well, I spoke with a friend of mine who's a shad bit smarter than I am, and she said it might be the psu... that'll be the second thing I do. memtest, then psu
What revision of the eVGA board do you have? If its not A1, I'd RMA it. The older versions were known to kill ram. If your onboard NIC is out, just RMA the board. But yes, I agree, test the ram first. I doubt its the PSU, but you could use the paperclip method to test it, if you have a multimeter.
Slow down your FSB a bit for a test.
If the pc works when running a bit slower then something is either overheating or running out of spec and your hardware is likely to not be faulty.
It could be a power issue, try unplugging all non essential items to see if it improves.
ie unplug other hard drives, DVD drives, powerful fans etc etc.
If it does improve, maybe the PSU is at fault or one of the other components is using excessive current.
I do have the first revision of the 680i. I plan on RMA'ng it for that reason. (and the ram killer fact)
Also, depending on how the memtest comes, I might RMA the ram also.
Thanks for your help
sounds good..
I'm not getting a stable machine with everything at stock voltage/speeds, so it's going to be RMA'd.
