Help me determe a hard freeze
osrk
My system based on dual 8346HE opteron with two 9800 gx2's and an Asus L1N64 ws/b mobo and it randomly hard freezes. I can't get a pattern on it. Sometimes it'll freeze after it's been on for 12hours other times it will take two days. The board is running all the latest drivers and it is not a heat issue. It could be a power issue I do have an air conditioner in the room. The computer will freeze, I'll be able to tell what time the computer froze because I can still see the clock, and when I reboot windows know's what time I rebooted at. What would cause this?
EDIT: Computer is running server 2003 R2 64bit
No there was no event on when the freeze happened. I have a sinking feeling that it could be the air conditioner. It's on another socket in the room but the light still flickers when it comes on (desk lamp). I have two computers on the same surge protector, one is rock solid (the one i'm writing from) the other freezes randomly.
Hmm just got off the phone with PC Power and Cooling and apparently the 750W silencer that i'm using might be pushed to the extreme. Would an overloaded PSU cause hard freezes that don't result in a reboot?
I would think that it would just shut down due to OCP if it's overloaded. Your system shouldn't be drawing 750W of power from the PSU though, so I'm not convinced that has a whole lot to do with the problem. For comparison, there are people in the DC forum running boxes with 3-4 GX2s on 750W PSUs without issue.
It could be the power supply. You could be getting reasonably close to the maximum, if not surpassing it (however, I got about 120W+ headroom with a very rough approximation of your system in the calculator below.) Not sure if it would result in that type of crash all of the time. My intuition tells me it would vary. I suppose if you could get your hands on another more powerful supply for testing, then you could find out quickly. Kind of a tough spot, as it may not be your power supply... it could be a lot of things. When I crash due to RAM errors, usually it results it a hard freeze (although it can certainly lock up under a variety of circumstances.) You really should run some benchmarking/testing software to see if your RAM or CPU causes errors. Like the above responder mentioned, I would try out Memtest 86+ that way you can test out of Windows. It could be that your Windows installation is faulty, too. You may need to narrow things down by testing your system with Memtest, Orthos, OCCT, Prime95, some GPU testing software and the like. See under which circumstances that you can produce errors (I.E., RAM testing, CPU testing, GPU testing...) The thing is, that were it your power supply, I think you would find that it crashes under load, rather than when it is idle.
Here is a power supply calc, although I am not sure if it is accurate: http://extreme.outervision.com/psucalculatorlite.jsp
I do know that supply is a nice one, but you obviously know that, too.
pull a gx2 out of it for a few days and see what happens...
Great idea. :) Although, I have to say I would think if it were overloading, it would do it under stressful conditions, particularly GPU loads. I've been wrong before, though, and I'm sure I'll be wrong, again. It may also be a software problem, or a problem between your software and motherboard (I.E., like a problem incurred from waking up from a sleep state, etc.)
