Well, after seeing some conflicting reviews of late, and various members dismissing reviews from other sites for a variety of reasons, I have decided "If you want it done right, you have to do it yourself." So, I am contemplating assembling a hard drive testbed.
I am on a really tight budget though, so that rules out a clash of the latest titans in the 300GB+ category. However, I do have a pretty large fleet of 160GB/7200/8MB drives in PATA (Seagate, Maxtor, WD) and could complete the field with entries from Samsung and Hitachi for less than $200. That would make a well rounded PATA test candidate battery.
On SATA, I should be able to pick up a WD740GD on the cheap as a payoff for recent 'consulting work.'
The decision for what other SATA drives to include is a little harder, although I am leaning towards assembling another group of 160GB drives, although only Seagate has a native SATA drive at this capacity point - using an aftermarket PATA->SATA adapter would be the same method that the other manufacturers use to make their SATA drives at the 160GB capacity point.
The other hardware will most likely be (hopefully, it would be a great new gaming system) a DFI NF4 SLI-DR, 2GHz Winnie or Venice, 1GB of TwinMOS SP, and either a 6600GT or X800XL. I will also take my own advice and 'head over to the PSU forum' to see about a quality PSU.
As for software, it will be Windows XP Service Pack 2. However, what software should I allow to run in the background? None, in the interest of a pure testing environment, or a small selection of background apps such as anti-virus, instant messager, etc for more realistic tests?
I would like to test the following programs/games:
Steam
HL2
Doom3 (it uses a unique method for storing the game data)
UT2004 (LOTS of small files)
Either C&C Generals: Zero Hour or Warhammer 40,000: Dawn of War
SimCity4 (I have a city of ~1 million Sims that is quite disk intensive)
Also, probably some app tests:
Virus scan
Zip/unzip
Open to suggestions!
The overall goal here is to gather as much useful enthusiast info as possible, on an enthusiast platform, in an enthusiast software environment. Any suggestions/corrections towards this goal are welcome!
Steam
HL2
Virus scan
Zip/unzip
