Help me design a loop (first WC venture)
mattjbak
I'm buying parts either in fs/ft or at some etailer. It'll end with an AC Cuplex Evo, Some x1900 block, not sure on pump, AC Aquatube, 2x120mm Rad (internal)... All in a Lian Li v1200b plus. Radiator will probably be at the bottom replacing the harddrive racks. The aquatube I hope to cut a hole in the top of the case and mount it there. Let me know what you think, and I need your advise on how to structure this loop. Also throw your parts my way if you have any... just offer in my thread. Thanks!
I'd recommend a Cuplex XT instead of the EVO, and a black ice pro 2x120 over the stock aqua computer stuff.
Agreed on the BIP2, and the XT. I have a BIP2 Xflow I could ship you for fairly cheap. The aquatube idea is a good one. Consider the 120mm "fit in a fan hole" reservoir over the aquatube if you want something a bit more "tank like" (I can send you a pic of mine).
Thanks for the info, I believe the xt is fairly expensive so we'll see how that goes. PM me about that radiator if you would. I think I'm set on the aquatube, I just like how it looks.
Was also wondering what fittings I should be picking up... From what I've read I think I want 1/2 tubing.
