Help me decided between these two (Antec and Enermax)
Ehren8879
Looking to replace a Ttake PSU that isn't giving me stable voltage on my new build. I'd like to keep the price around $80 or less, but have some decent, reliable power. Which of these two would you choose? Would you suggest another decent PSU for the price. I'd like to have wattage in the high 400's to mid 500's.
The candidates:
Enermax
http://www.newegg.com/Product/Product.asp?Item=N82E16817103457
Antec
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
I'm partial to the Antec... I dont know why, looks better I guess.
Thanks
I'm partial to Antec as well myself. There really are several quality companies out there right now. I would be a great idea to read thru the stickies atop this forum. There are some recommendations as well
And an opposing view...I've had my Enermax Noisetaker AX 470w for going on two years now, and it has been rock solid. Before that, an Enermax 430w which served me well for four years (removed it only because I needed more power on the 12v rails; in 1999 when I bought it, PSU's were designed for heavier distribution on the 5v rail).
I think most of Antec's product is good for average PC's, but if you plan on doing more, you need one of Antec's pro-level PSU's, or you won't be getting anything special.
I'd also look at Fortron/Source (also known as FSP Group) and Seasonic. Both make some very good units.
Newegg knocked $10 off the price of the Antec and offered free shipping so I went with that. Here's hoping my voltage fluctuations go away. Thanks for your input.
