Sidrack Marinho
- Jul 28, 2008
I've been using CRTs for at least 11 years, my last model was the Samsung SyncMaster 997MB (19") bought in 2004 (and it's still here). I did some research about LCDs, it looks like no one can never be 100% sure which model can fit my needs.
I am going to use my monitor specially to watch movies (Blu-Ray/DVD/DivX), and ocasionally play games, plus spending quite some time everyday working on Windows/internet.
1) What kind of model do you think will fit my needs?
My computer:
Q9450/Abit IP35 Pro
VGA: 8800 GTS 512 MB (GS92, EVGA)
2) One thing I am not sure: all LCD monitors have the HDMI connection? Do I need to connect the HDMI cable into my monitor or the VGA card? I need to know which one (VGA card or LCD/monitor) will give me the best image/sound quality when sending the signal into the Plasma TV.
I am going to use this Blu-Ray drive. That's not all - the movies will be decrypted to my Hard-Drive, with no compression (or retaining a good bitrate/size, larger than 8 GB). I am going to decrypt those discs using AnyDVD+HD. The reason for that is simple, playing my movies from my HDD and sending the signal to my TV.
What do you recommend? This is very important for me.
3) Will all LCDs play games/movies using different resolutions the same way? I was affraid of using on my desktop a very high resolution and all font sizes started looking very small (and the rest). The only good proportion on my 19" CRT (Samsung 997MB) was 1024x768.
4) One (apparently) good monitor related by members of Hardforum was the NEC Wuxi (2490). The problems: quite expensive, and even if I could afford it, no one sells that kind of monitor here, I won't be able to do the "real test" (with my eyes, of course).
I never knew a "real good LCD", judging for what I saw briefly, was not pleased. The image always looked very artificial, the crude pictures from my CRT were real. I can't say for sure now.
Can you really testify the difference from a cheap LCD (perhaps old models from years ago) to a brand-new-priced-1K is that significant?
Thanks.
