help me decide
rysher
help me decide between:
[font=verdana, arial, helvetica][font=Arial, Helvetica, sans-serif] Aqua Computer Airplex Evo Radiator
or
[/font]
[/font][font=verdana, arial, helvetica][font=Arial, Helvetica, sans-serif]Black Ice Micro II 80mmx2
thanks.
[/font]
[/font]
It would be helpful if you posted all of your components and your desired loop.
madmat said:
Are you unable to mount a 120mm rad?
i can mount a 120mm rad, but i thought a 160mm rad is better than 120mm. i wanted it internal, and there is just no space for a 240mm even if i want it. so my option is 160mm or 120mm. but like i said, i thought 160mm is better.
was thinking of this set-up:
RES> PUMP> RAD> CPU> RES
was thinking of getting these parts:
RES: Tanky - Dual 3 1/2" Bay Reservoir - Clear or
[font=verdana, arial, helvetica]Aqua Computer Aquabox Plexi 3.5" Drive Bay Reservoir
PUMP:
[/font]12V DD-D5 Pump
RAD: Black Ice Micro 2 High Peformance Radiator or
[font=verdana, arial, helvetica]Aqua Computer Airplex Evo 160 Heat Exchanger - Dual 80mm Radiator
CPU BLOCK:
[/font][font=verdana, arial, helvetica]Aqua Computer Cuplex Evo
how many fittings do i need on this set-up? i was looking at 1/2 fittings, but i can't seem to find the fittings for the aqua computer cuplex that is 1/2.
comments and suggestions please. this is my first water cooling. i dont need GPU cooling right now or northbridge maybe later on i will.
[/font]
thanks for any help. the sooner the better, as i am planning to order the parts tomorrow, monday. thanks again.
P.S.: i dont want any swiftech parts, as i've read from this forum that their RMA sucks and too much problem. I just don't want to deal with that.
Aqua Computer is Euro Small-bore. No 1/2".
No, 2x80 < 1x120.
A single 120mm rad has more area than the 2X80mm rad though. I've gone with dual 80mm rads and yes, they do work but if you've got the room for a 120 then by all means don't hamstring yourself.
No, 2x80 < 1x120.
how do i convert this to 1/2? what will i get to fit it w/ 1/2? thanks
Try finding the 3/8 threads, then run a small amount of tubing, then a 1/2" male-male.
Or, you can buy a designed-for-big-bore block, like a Storm.
Why 1/2" instead of 3/8"? Especially if you want the Cuplex EVO.
There will be restriction downconverting a 1/2" loop to the 4/6/8mm channels found inside the Cuplex EVO. The stock threads on it are G18", which are rather small too.
I dont know if the EVO will scale well with the D5 pump - since there's only a certain amount of an increase you'll get with more flow, it might not be all that great for that block.
