As you can see in my sig, all of my current hardware is running @ stock values.
I had a thread going in the OC forum last spring/summer with my trials and tribulations of overclocking the very same hardware in question, and after many months of semi-stable performance I finally got fed up and threw it all back to default. I strongly suspect that the OCZ 2-3-3-8 PC3200 ram shown in my sig was the culprit, but also would not be too terribly suprised to find that my specific 3000+ Venice has a weak memory controller.
So 8 months later, I've been bitten by the overclocking bug again - and having come into a bit of extra spending money, I'm going to take another stab at this.
What I'm aiming to do is keep the current board (I can't see any reason why this board won't last me through another couple of CPU's - even with overclocking, being DFI - but if I'm wrong let me know now) - so the first step is new ram. Once I get the new ram, and find that either my 3000+ Venice just isn't going to hack it, a new processor will be next on the list.
So to start - the memory.
Should I stick with PC3200 and just aim for 2 x 1gb with incredibly good reviews and tight timing - or would I buy myself some longevity (for future overclocks with future CPU's) by going for a reasonable PC4000 set of 2 x 1gb instead?
Now I've long since come to understand that 2-2-2-5 is the goal of kings for PC3200, but when looking at the PC4000 stuff my limited understanding is being taxed. I'm seeing 3-3-4-8, 3-2-3-8, and a wild variety of other timings. I understand those are @ PC4000 speeds - but what would I expect those to translate into when running lower (ie; assuming I get lucky and I can push that 3000+ to 280-300 HTT - what ram if any will hack it at 1:1)?
A few of the ideas I've been looking at (NCIX.com here as I'm Canuckistanian);
OCZ Platinum EB PC4000 2GB 2X1GB DDR500 CL3-3-2-8 - ~$388 CDN
Mushkin Redline XP PC4000 2GB 2X1GB DDR500 CL3-3-2-8 - ~$406 CDN
OCZ Gold EL PC4000 2GB 2X1GB DDR500 CL3-4-4-8 - ~$316 CDN
or would I be better off buying two singles (insofar as I've seen that'll be more expensive, and runs the risk of having mismatched sticks);
OCZ Gold EL PC4000 1GB DDR500 CL3-4-4-8 - ~$196 CDN EACH
OCZ Platinum EB PC4000 1GB DDR500 CL3-3-2-8 - ~$202 CDN EACH
Or am I way off base here?
Bear in mind my selection is a little more limited than those of you with access to NewEgg (unless NewEgg has suddenly brought back that ability to ship to Canada and I missed it - and even then the risk of customs/border charges negates any possible savings to begin with).
