help me decide on a reservoir please...
jmahler
this one will look nice in the case I'm getting (the gigabyte 3d aurora), but i'd like some alternatives...
http://www.sharkacomputers.com/thaqm3warele.html
(and hey, might just pair it with this one for the hell of it -
http://www.frozencpu.com/ex-res-79.html )
here's the biggest poopy issue - i run 8mm/10mm id/od tubing from a euro kit, and that's not changing.
also, I want to make sure it's easy to access for filling and topping off in case of evaporation or a minor leak or whatever.
here's some alternatives:
http://www.frozencpu.com/ex-res-64.html
http://www.frozencpu.com/ex-res-34.html
any thoughts guys? the bling bling factor is kinda nice but not ridiculously important. i much, much prefer reliability and performance.
the thermaltake is my first choice, like i said, but i would like input either way...
and please, for heck's sake, don't you dare say "build it yourself". i couldn't easily think of a faster way to ensure that my computer will get drenched in a liter or two of chemically treated distilled water... and i don't think my opty 165 would like that so much.
thanks....
jesus christ, frozencpu is raping on the thermaltake bay res/flowmeter combo :eek: $59 while i got mine at sharka for less than $45! I like it, it looks cool enough, plus since it is g 1/8 threaded it's easy to change to different fittings fittings.........
edit: it's $42.95 v $59 at frozencpu :eek:
thanks for the better price find. is the flowmeter res an easily fillable one? i was thinking that it might actually just wind up being my entire res.
Will I know you said the bling bling factor didn't matter but if you got the black gigabit case I just couldn't resist . 2 of these mounted on the top of your case using blue pc ice as a coolant(or simular) these would look just to dam boss for me not to suggest it.
Beam me up scotty
http://www.xspc.biz/reservoirs.php
How about a new Aquabox? You can see some better pics here:
Or you also might consider using an Aquatube:
that aquabox is very pretty - it's the price, though, of both of the thermaltake res's put together... hmm
how easy is it to fill? the thermaltake bay res has a top hole that looks easily accessable...
