Help me decide (AMD or Intel)
jrbryner
It's time to do an upgrade on my main machine. Same old story as everyone else, I'm looking for something that's fast, but isn't going to really bend me over on my checkbook. Not going for o/c here either.
So I'm looking at either:
Option 1:
Athlon 64 3200 (512k L2)
DFI Lanparty nForce3 250GB
Option 2: (not too familiar with the Intel party, so help if these are out of place)
Pentium 3.2gHz (Prescott)
Asus P4C800-E Deluxe
I'll be taking the stuff out of my current computer (in my sig) and putting it in this one. Which way should I go? The price difference is negligable, I'm more concerned about speed & stability.
'appreciate the help.
jrbryner said:
Option 1:
Athlon XP 3200 (512k L2)
Athlon XP 3200 with nForce3? Do you mean an Athlon XP 3200 with nForce2, or maybe an Athlon 64 3200?
What will U be using the machine for.
For normal uses and users A 64.
For HEAVY Graphic calculations or compressions and so on. a P4..
I'd be using it for normal everyday stuff, games, browsing, plus 3D work, Photoshop, design stuff.
Might want to think about signing up for M$'s 64bit WinXP and the Athlon 64. According to a few websites there is up to a 25% increase in 32bit apps with this kind of rig. Althought P4s traditionally have a stronger FPU for your 3D and graphic rendering I'm sure an increase of that magnitude will not only make the P4/A64 question moot...but it will make your games scream as well. The only real question there is 64 bit driver support. Might take a little leg work but it's definitely worth a look. :D
