r0b0tc0rpse
- Feb 22, 2008
take a look at my mod rigs link
http://www.evga.com/community/ModsRigs/comment.asp?sysid=10164
Keep in mind this is only air cooling
Now i do not have fans in the top of my case... and i have only the stock front fan (its really slow)
I have been considering installing a 110 cfm in the front(factory front one is very low cfm), 2 110cfm's in the top
I have also been considering a 133cfm fan on the window...
Now here is the thing, I could either point it at the video card(s), or point it at the CPU/chipset/memory, and then make a plastic plate to block the inlet fan on the tj09 to only blow into the bottom half of the case.
what bothers me with the tj09 is that there is no fan to feed the CPU from outside air.
another option i have considered is a bay fan but i'd like to find a bay device sans the fan that matches the aluminum / perforated sheet look of the case...
(i already have 1 133cmf as exhaust in the back)
what do you think? based on the pictures and what i discussed here, is there anything i can do to optimize my case?
