Ever since I got my Opty 165 (currently @ 2.4GHz), my Vcore has been jumping all over the place with my Antec SP 500W. I been looking around and found these PSU's, which one would you choose?
Specs:
Opteron 165 @ 2.4GHz (trying to go higher but PSU holding back)
Epox 9NPA+Ultra
ATI X1800XT 512MB @ 650/675 (PSU may be holding this back, black screen if OC higher)
2x1GB GSkill PC3200
SB X-Fi Xtreme Music
2 SATA Hard drives
1 Optical drive
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=373100 Corsair 520W
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=270341 Enermax Liberty 500W
http://www.newegg.com/Product/Product.asp?Item=N82E16817128001 Hiper 580W
http://www.newegg.com/Product/Product.asp?Item=N82E16817128006 Hiper 530W
http://www.newegg.com/Product/Product.asp?Item=N82E16817703005 PC P&C 610W
I'm leaning towards the Enermax Liberty, amps look good. Is the PC P&C overkill for me? I plan on upgrading the video card in maybe 6 months, or when I feel the need to.
If there's any other PSU you would get at those prices, which would it be? I would prefer modular as you can see, I won't be using much cables.
Thanks
Specs:
Epox 9NPA+Ultra
2x1GB GSkill PC3200
2 SATA Hard drives
1 Optical drive
Thanks
