Help me choose large widescreen for gaming.
oqvist
Price well I am all for bang for the buck but up to 2000$ is acceptable I guess.
It´s primarily for gaming but also for DVD and some TV... But Gaming focus number one.
I am thinking minimum 24 but preferr 32" or larger.
Now back projection CRT, LCD TV is the options right? That Dell 3007 30" seemed to have to high response time and it was expensier then the larger LCD TV:s. Most because it´s supporting a monster resolution I don´t think I will be able to power many games with.
So it looks like either back projection CRT or LCD TV?
I have heard Sony is the best but htey have a zillion different tubes. Is it worth it going all out on a sony 32 LCD TV? Or am I better off with a Back projection CRT? that gives me 50" for less but at a slightly lower resolution? Which gives me the better image for gaming? Sony is 8ms so shouldn´t be a problem with ghosting. Back Projection CRT:s how are those?
Sony uses 3 lamps how long can you expect to run them before the brightness get all crappy? Quite expensive to exchange also so maybe it´s not really cheaper then those LCD TV:s?
Image quality is important since I am going from a 22" diamondtron. I am sure widescreen and the sheer size will make me feel very happy with it but I don´t want image quality to suffer to much.
So I am looking for bang for the buck but still much focus on bang :)
I am feeling wide. I think I am going for this one Sony KDL-32V2000...
Green light?
I'd suggest the 37" Westinghouse LCD Television. From what I hear, it's an excellent display. Look around here for some reviews :)
Realistically nothing can beat a crt at gaming. They still have widescreen hd-crts available but may not for much longer so you may want to look into a widescreen hd-crt. I think 36" is the largest though.
might wanna check out avsforum.com (not sure if thats right url) the guys over there can tell you whats good.
wonder what would cost more, the monitor or the shipping?
crt only is better if you have an entire room to sacrifice.
Westinghouse don´t appear to be sold in Europe... Not Sweden anyway are they using another name here?
Price seemed okay but I read bad dark levels which are not good for doom gaming lol. Also since it´s a budget choice I guess the image quality isn´t up to par with the sony?
As for these HD CRT TV:s that is backprojection monitors right? How suitable are those for gaming?
Or if you perfer no input lag, true colors, deep blacks, and no ghosting.
While LCD's have a few things goin for them they still cant compare for video or gaming quality.
Take a look at the Samsung LN-S3251D, it's gotten great reviews, one of the best 32" panels, only behind the expensive cold cathode backlit 3292 and 32" Sony XBR-something. the 3251D uses the same S-PVA panels that the sony S2000 uses, its just a bit cheaper, because you're not paying for the Sony letters. I took a look at it yesterday and the white version, looks amazing, and very stylish outside. The speakers are hidden, and not all that good, for me that's a plus since I have a 5.1 system, might be bad if you don't have other speakers that you will be using.
