Help me choose components :D
Monshies
1. What will you be doing with this PC?
Gaming!
2. Will you be overclocking?
Nope
3. What's your budget?
300 to 400 Euros
4. Where do you live?
Germany, I have amazon and computers store nearby
5. What exact parts do you need for that budget?
Motherboard ITX (if not the cheaper available please tell me why) :)
Micro (i5 woud be nice) (also interested on AMD options)
RAM
(to fit on a Cougar QBX case)
6. If reusing any parts, what parts will you be reusing?
I have the HDDs and the PSU (cant remember psu brand but its a big one) (it fits the case too)
I have a 970 gtx
7. What specific features do you need in a motherboard? RAID? Thunderbolt? Crossfire or SLI support?
Would be nice to have bluetooth
8. What resolution output do you need?
4k playback, 1080p playback, etc for HTPC or give a vertical/horizontal resolution for gaming SFF rigs. Do you need multiple monitor output?
10. How comfortable are you with custom case design/modification and electrical wiring?
Cool
14. When do you plan on building/buying the PC?
ASAP! I wanna game! :D
Ok so after a little research ive figured im gonna need to up my budget to 450 euros
Im currently looking at:
Intel - Core i5-7500 3.4GHz Quad-Core
And either
Gigabyte - GA-B250N-Phoenix WIFI Mini ITX
or
Asus - STRIX B250I GAMING Mini ITX
So, does anyone have any experience with this motherboards? I like the gigabyte a bit better because of more usb ports in the back. But other than that they seem exactly the same, only 10 bucks difference.
Plus 16gb of ram thats around 150 bucks... i'll see whats in the store
All this to fit on a Cougar qbx case :) and i have a psu and a 970 gtx waiting for this
Happy to hear your opinion guys!
Cheers
Update:
I noticed my old PSU has the 4 pin connector for the motherboard, and this 2 i listed have 8 pin sockets, will the 4 pins be enough or can i get an adapter to feed more power from another molex?
