I am considering running two loops, one for yet to be obtained i7 CPU, and second loop for GTX280 GPU. I need advice on the GPU loop.
I would like to cool the GPU with a PA120.3, but would require some chop, cut, rebuilding to get the radiator to fit in the case. A PA120.2 would go in by simply adding fan holes.
I am wondering if the larger rad and extra work would be worth any added cooling benefit.
Is there a way to figure out GPU temps of PA120.2 vs PA 120.3 and D-Tek Fuzion GFX 2?
