Help me choose a mobo, CPU, RAM combo
Ladyhawk
Hi Folks,
Due to illness, I've been out of the hardware loop for awhile. I may have nearly rounded up enough money for a new motherboard, CPU and RAM and would like to get the best I can afford. Usually, I don't buy the latest generation, but the best that can be purchased just under the price break. I still have a KT133A mobo with Thunderbird and PC-133 RAM, so it's time to upgrade. :) At some later date, I must also upgrade my video card.
So, can you help me out? What's the best solution just below the price break? And what wattage power supply do I need to run the thing?
Thanks,
LH
Definitely let us know a price range. We'll happily recommend something to you.
Do you wanna use AGP or PCI-E???? Do you wanna OC or use standard stock items??? You can really get a nice system with AGP (still) but by the looks of things you dont upgrade that often. I agree... How much cash??
Holy cow, I've been out of it for awhile. I'm assuming PCI-E is an upcoming standard for video cards? I suppose I could google it. I was just assuming AGP.
Um, how about a price range of around, say, $300.
I don't need to overclock. I used to play around with it, but with the hotter running CPUs it's pretty tough to get much of a performance boost unless you have special cooling...or at least it was last time I checked.
With 300 Ure not gonne cut it for a CPU/MoBo/GFX/RAM combo and I dont think U have to much that can be reused in your old system, better let that become a backup as it is. Have look at www.anandtech.com and look into the guides there. They published a budget system guide last week.
CPU: 150-200
RAM: 100
GFX: 200-300
Mobo: 100
= 550-700..
Id get:
AMD A64 3200+ (Venice)
DFI-DAGF (MoBo)
a 6600gt (PCI-E)
and 2*512 decent RAM, Twinmos or so.
But in that case U want to get the 1.8GHz 256kb Cache CPU... But I guess your current GFX isn't that good that its easily reusable.
for an all new build i would go PCI-express
but you can bargin hunt a little more in AGP /754
since prices are dropping on pci-express and nf4 stuff -- the long run you'll be better off with pci-express/nf4 /939socket
even then--amd is doing the socke t"-hookey-pokie" --AMD must be cross invested with the MB makers --LOL?!
muct be going back to the socket of the month club ??-- :cool: :eek:
Thanks, folks! Keep the suggestions coming. :) I really appreciate your help. I've been wanting to catch up on hardware, but I've been out with surgery and things change so fast, as you well know. :)
This will give me a place to start my research. You're very kind. :)
I do game when I have a decent system and the time, so eventually I will want a good graphics card. Right now I still have an old GeForce3. I know HL2 is pretty decent. Are there any good multiplayer games out there based on the HL2 engine? What are some other good FPS games that are popular online?
The 1.6GHz Sempron is the best Price to performance CPU on the market, especially when you overclock.[/i]
How easy is it to o/c this chip? Can it be done through BIOS or is some kind of modification necessary? What kind of heatsink/fan is needed to ensure proper cooling? How much of a performance boost can you get? :)
BTW, I would be willing to spend a little more to get something that will last me for awhile. Of course, CPU, RAM and mobo have to be purchased at the same time, so that's the difficulty.
The Rock'n Roll FPS right now is Battlefield 2
But then Ure up there at about 1k$ to get it running well... It very demanding.
If U take my previous post and add another Gb (so U have 2*1Gb) oc The CPU a bit and get a 6800gt instead Ure setup to Rock'n roll in BF2. DOOM3 needs about the same to run well at high res with decent eyecandy. And either way U WILL need a new PSU as well and then its just a case and a HDD to fgo til U have a 2nd system.
Which brings me back to my orevious point. U will have to buy so much anyways that a upgrade isn't worth it its better to keep Ure ol system intact and use it as a backup or server.
That SmprOn system will NOT cut it with todays FPS:s The CPU is pretty ok but U need a new GFX on top of the listed RAM/MoBo anyways and U sacrifice your existing system to do it.
Its just not worth it IMHO. Did U look at anandtechs guides?
What resolution is your monitor? (for games)
I would suggest to look at the medium guide at Anandtech thats the sweetspot Price/Performance.
http://www.anandtech.com/guides/
Budget system (July - 05) http://www.anandtech.com/guides/showdoc.aspx?i=2475
Highend system (May - 05) http://www.anandtech.com/guides/showdoc.aspx?i=2426
Those are very good places to start.
As U can se in the summary http://www.anandtech.com/guides/showdoc.aspx?i=2475&p=9 U need about 800$ to go somewhere and then I would still add a few $s and get a 6800gt or Reardon 800XL to be able to play some games. That will (with a decent aftermarket HSF) keep U for another year or so. and If U get a s939 MoBo U have the option to upgrade the CPU later and get some more powa...
Here's some parts for those on a strict budget:
AGP Motherboard $71
3000+ Venice $143. Will do ya just fine. Quite overclockable. Can easily hit 2.0 - 2.4 (maybe even a lot higher, depending on the week of manufacture) with the stock heatsink and no increase in voltage = runs very cool.
AGP 6600GT $144 after $15mir. Can get the job done. Not the fastest, but not the slowest.
** or **
AGP 6800 $189. Good card for playing games at higher resolutions than the 6600GT (1280x1024+)
Memory get 2 of these @$41 a piece.
TOTAL: $440 for 6600GT, $485 for 6800nu. Does not include shipping.
Important: Make sure your current power supply has at least 20-22 amps on the +12v rail, just to be safe. You can probably get away with 16-18A at the bare minimum with a 6600GT and non-overclocked cpu.
If you would rather have PCI-e, let us know, as we can make more recommendations (although it will cost a bit more right now).
I've got a 1.6 Ghz Sempron overclocked to 2.4 Ghz (50% OC) on stock cooling. No troubles with the system whatsoever. See sig for components.
I hate to say this but there is always the OEM route. You might want to see what the builders have to offer in a selected price range???? If you dont have time to do it yourself.
If you want a slick place to start,since this looks like a new project......
Shuttle SN25P....excellent small form factor,350W PSU, AMD 939 socket, media reader, very quiet, runs smooth and cool. NF4 based mobo.
AMD CPU of your choice
up to 2 GB of nice corsair value RAM
GeForce 6800GT
A HDD of your choice
This is a nice looking, quiet, small rocket launcher.
AGP Motherboard $71
** or **
If you're not going PCI-e, there is really no point whatsoever to getting 939. May as well get a 2800+ or 3000+ 754 (2800 newcastle is clocked the same and has the same cache as venice 3000+, newcastle 3000+ is 200mhz faster than equivalent venice). Should overclock just as well as venice (at least 2.3ghz, I would imagine).
Better yet, get a sempron, overclock it as far as you can and spend the $100 you would have spent on venice somewhere where it will really count, like on a video card. That $100 is the difference between a plain 6800 and a x800xl, which will make a bigger difference in games.
There's lots of reasons for going S939. X2 being one of them.... At some point down the road just drop it in and that's all that needs to be changed. ;)
And the X800XL is a very fine choice for the money, if you don't mind upgrading again when DX9.0c, SM3.0, and FP16 HDR requirements appears in more and more games over the coming months. And at the length of time (2-3+ years?) the OP wants this system to last without upgrading, I can't recommend ATIs latest offerings. But they can be a little faster in some games, that part has been proven time and time again.
Realistically, you can't get 2 or 3 years out of a $300 system if you want to do much of anything demanding on it. The best you can get is either a cheap ass OEM machine, or a platform to build on over the next couple months.
I think you should forget about $300 as a starting point. Save a little more money. If you could salvage stuff from your current PC, then you'd be better off, but as it stands I don't think that KT133 will be donating much of anything. If I were in your shoes, this is what I would get. Its over your $300 budget, but not too much. It will give you enough power for now and some room to grow for the future, should you choose to upgrade.:
$65 shipped -
REFURBISHED: DFI LANPARTY UT nF3 250Gb ATX AMD Motherboard - OEM - Best overclocking MB for 754, period. Its a refurb but it should be just fine. Worst case scenario, if its not, you can RMA it to the manufacturer. It's pretty doubtful you'll have a problem though.
$65 shipped -
REFURBISHED: AMD Sempron 2600+ Palermo 800MHz FSB 128KB L2 Cache Socket 754 Processor - OEM - Its cheap, its not 32 bit, but the integrated memory controller means it's faster than an equivalent Socket A chip. Should overclock like mad. Also a refurb, but strangely enough newegg is suddenly out of new ones when they weren't just 3 days ago, and now they've got all kinds of sempron refurbs that they didnt have 3 days ago. You figure it out.
When you can afford it, upgrade to the 3700+ clawhammer or a mobile chip. Either one should set you back around $250 and will give you a solid boost in performance.
~ $40 shipped -
SkyHawk MSR-4610 Silver 1.2mm All Aluminum ATX Mini Server Case - Great aluminum case with a sliding motherboard tray. Since you'll be upgrading this computer, that feature will come in useful. Its on par with early Lian-Li models at a fraction of the price.
$44 shipped -
FSP Group (Fortron Source) ATX400-PA 400W Power Supply - OEM - A solid PSU at a good price. Dual 12v rails for added stability. Output +3.3V@30A, +5V@30A, +12V1@18A, +12V2@18A, -12V@0.3A, +5VSB@2A.
$152 or $159 shipped -
Either SAPPHIRE RADEON 9800PRO 128 R Video Card - Retail or XFX PVT43ANDF3 Geforce 6600GT 128MB 128-bit GDDR3 AGP 4X/8X Video Card - Retail - This all depends on your own personal preferences, what games you play, etc. They're both, for all intents and purposes, pretty much equal as far as performance goes. There's plenty of information available to compare the two so I won't get into that here. Either one will run every game available right now at a very playable resolution and framerate. Maybe not as detailed as a 7800gtx, but then again we're talking ~1/4 the price.
$93 shipped -
CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM System Memory - Retail - I think 1gb is a worthy investment, as it's enough for today and for another year or so. I've got 512mb on my current system and I'm feeling the pinch. BF2 will make you wish for 2gb, and that's a trend thats going to continue with upcoming software titles. I simply wouldn't reccomend only 512mb at this point in time unless you absolutely cannot afford 1gb. I wouldn't get 2 512mb dimms either. Spend a little more, get a 1gb dimm now, then another gb later when you get the chance. This isn't absolute though, ultimately it's up to you. Don't worry about better timings or any of that crap, you're on a budget.. Just use a divider to keep it at or around 200mhz when overclocking and you'll be ok.
You need a cooling fan. I would recommend a Zalman. Get the $30 one. If you want to skimp, get a $10 cpu/hsf combo and be done with it.
The only other thing to get would be a hard drive. I'd reccomend one from newegg, but if you keep your eyes peeled you can find all kinds of good deals with rebates and coupons going on for hard drives all the time. Your best bet would be to get in on one of those and get as much storage as you can. Or, you could spend about $60 at newegg and get an 80gb drive. Up to you, really.
I'm not going to reccomend a DVD-R or CD/RW. Whatever you have is enough to install windows with, beyond that your needs will dictate what you get. I imagine you also have a mouse, keyboard and a monitor, so I won't bother recommending those either.
My total, not counting HD or HSF is ~485 shipped. If you are able to overclock this computer sufficiently (and you should be able to with that DFI board), you should hit close to 3500+ speeds with the sempron @ 2.4ghz (300HTT, use a 2:3 memory divider). The lowest price for a 3500 on newegg is $250 OEM, which is about half the price of this system when you figure in an HDD and a HS/F combo. Now granted, it wont be 3500+ speeds ALL the time, some apps will miss that cache more than others, but you'll be close enough and for a fraction of the cost.
Hope this was helpful.
Hmmm, $485 for a refurbished Sempron based system upgrade when the S393 system I listed is about in the same price vecinity (minus the psu and case)? I don't see how that would be better for longevity than the S939. Doesn't make sense... It would be smarter to get a newer generation socket architecture and processor if this system needs to last a while. Just my opinion though....
Also if u didn't notice the OP said he wanted to be able to play new PPS (Yupp thats BF2, Doom3 and maybe UT2004) and thats the benchmark to reach w. the system.
Thats just it. For your system to be complete its another $100 or more. While the difference between $485 and $585 might not mean much to you, it might to them. I was going for the lowest cost complete system I could build without using sub-par components.
I hate to ask this BUT why get a bunch of outdated referbished stuff when you are going to hold on to a system for awhile. Youll find yourself handcuffed by the hardware??? Just spend the money on a nice system that you can up grade easily. I agree a nice NEW 939 system will take more upgrades than the REFURB. You gotta ask the question, why was it refurbished....cuz it was RMA'd in the first place. You get what you pay for.
Because some people aren't made out of money and if you're going to spend as little money as possible you'd be better off buying a refurbished product from a reputable manufacturer than a new, lesser product from a lesser company.
I think we can all agree that the ideal situation would be to save more money, but thats not what this person asked for. Why not get the most power they can AFFORD, NOW, instead of continually waiting for something better to come along? $300 means $300, not $600 or $800 which is what 939 would end up costing. At least what I've outlined is realistically attainable. If the person in question is stating $300, don't you think saving up another $150 is a bit more realistic than expecting them to save up another $300 so they can get a complete 939 system?
The reason I recommended socket 754? the DFI lanparty UT nf3 board is a great overclocker. So is the 90nm sempron. 754 isn't any more of a dead platform than 939 is when you take into consideration how often this person gets new components. When and if this person does decide to upgrade, they can get either the 3700+ claw or, if they're smart, a newark mobile that will most likely hit 3000mhz on air if not more. Even if they did save up a little more money to begin with, it would be better spent on a 6800GT or X800XT and either a newcastle 939 or a 256k cache sempron, not socket 939.
The only reason I recommended the refurb is to save money for a better power supply. If they wanted to take a chance and cut corners, they could get a cheaper PS/case and get a new motherboard. I think their chances are better with a refurb DFI and a quality PS/Case.
As far as the Semprons being refurbished, I highly doubt that 3 different types of sempron chips going out of stock in the new items section all at once and 3 different types of semprons showing up in the refurbed section all at once on the same day was just some strange coincidence. I know this is the case because I've been watching the 754 chips closely waiting for the new mobiles to come in.
I can completely understand your logic and viewpoint, and I respect that.
But there is also the option of a sequential purchase plan. The OP can use the system they have now while systematically collecting the parts for the upgrade over time.
Month 1: Buy the memory.
Month 2: Buy the PSU and Case.
Month 3: Buy the motherboard.
Month 4: Buy the CPU.
Month 5: Buy the Video Card.
This can all be done in less or more time, as money permits. It's what I did with my system (I had no choice, I preordered a Venice and then decided to purchase better components as money allowed instead of settling on something sub-par or last-gen). This might be a viable option where money can be tight for others, as well.
I agree save it up and get stuff thats new and upgradeable, dont go for the lost and found. The OP said she wasnt gonna overclock anyway. BAH.
You might try MSI RS 480M2-IL motherboard for $88.00, PQI 1GB (2x512) DDR400 $81.72, and an Athlon64 3000+ Venice core 939 retail $146.00 total $315.72 delivered from NewEgg.
The motherboard has onboard ATI Radeon X300 video it will play older FPS's until you can upgade to a newer/better PCI express videocard. Has both EIDE and SATA, onboard LAN, onboard firewire, 4 usb's, vga, s-video and composite video out, 6 channel sound with spdif coax out. It's quiet, stable, and will run rings around your old system and you can use your old harddrive and optical drives and it only requires a 300W powersupply (has a 24 pin Power connector on the board but accepts a 20Pin power connector) no need for an adapter! It's not a motherboard for Overclocking! It has no real bios settings for it. But it fits your budget.
