Renegade_09
- Feb 24, 2010
1. Budget
$600
2. Seating distance
I'll be using it as a PC monitor to watch movies at 7-8ft and do some internet browsing at around 2-3ft. I'll also use it to play games on my PS3.
3. Size/placement limitations
I think 32" is the biggest I'll go for
4. Uses and sources
Web browsing, console gaming, and movies
I'm debating between 720p and 1080p. Since most games are 720p on the PS3 I'm not sure if I need a 1080p TV. I think I can live with 720p for web surfing also. For movies I'll be sitting 7-8ft away so I'm not sure if it's worth for $200 extra for a 1080p TV.
Here are the options I have in Canada
720p
SONY KDL32L5000 $420
SAMSUNG LN32B360 $400
1080p
Panasonic TC-L32U22 $600
Toshiba 32RV525RZ $500
LG 32LD450 $600
I really want an IPS panel. The only one I'm sure is an IPS panel is the Panasonic.
$600
2. Seating distance
4. Uses and sources
720p
1080p
LG 32LD450 $600
