Hey guys,
I'm looking to purchase a new case and was looking for something that's very quiet but also very strong. I was thinking somewhere in the $100-$150 range. Essentially I wanted a Silverstone TJ-09, but there's no way I can justify spending $300 on a piece of metal. Basically I want something thats black, quiet, strong, windows are cool but not required, and preferably little ot no LEDs. I've currently got an X-Dreamer II, and its loud and the LEDs are annoying. Anyway, I've narrowed it down to the following cases, so which would you choose and why? I am open to other suggestions however. And please don't recommend any coolermaster, or any other antec cases --- I think they are all ugly
I know the P182 is probably one of the most quiet cases, so I'm considering it, but I dunno...
Also, the Lian-Li cases I've chosen seem to be made of quality material, but are they quiet? And i don't really see the difference between the Lian-Li's I've chosen besides the few cosmetic differences... is there someone I'm missing? Maybe some are better than others?
How bout that Silverstone?
I'll also probably be pairing it with a Corsair 620HX PSU to replace my Apevia 520 one.
Anyway, I appreciate your feedback.
Links in case you need em:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129025
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112099
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112040
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112116
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112025
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112100
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163036
